Tempering Valve Installation Question
JerryR
Active Member
Florida
With the 40 gallon Water Heater set to 120 dF I would run out of hot water before I was able to fill the roman tub.
I set the WH thermostat up to 140 dF and was able to fill the tub without running out of hot water. (South Florida, cold water temp was 76 dF last night) Final temp in tub was a very warm 106 dF. I don’t want to leave the WH set that high as I have a 7 year old grandson who spends several nights at our house.
Base on this I plan on installing a 50 gallon standard GE WH set to 140 dF and Watts L70A Tempering valve set to 120 dF.
The Watts installation instructions state “install valve body as illustrated in diagram. Valve must be trapped 8" to 12" as shown.” What i is shown is to install a 8”-10” trap and mount the valve in an awkward position below the water level of the tank. Pictures of real life installations I’ve seen just shot the valve mounted above the tank without any trapping.
What is the purpose of the trapping and is it critical? Will it work reliably without being trapped?
Jerry
Without that dip/trap, you might end up with constant circulation and waste energy. Since hot water is lighter, it wants to rise, but by having that go down, you only get some conduction (you could insulate the pipes), not convection.
As piped in that diagram, you've also got a tap of untempered water which works quite well for things like a dishwasher and washing machine. That extra bump in temp can make a huge difference in how clean the dishes get and how well the detergent dissolves. It may not be an issue if you have a heater in the DW, but using that will lengthen the cycle times - same thing on a WM, if it has the ability to heat water (some do for a sanitizing cycle).
The next one I install the way the drawing shows it, will be the first one. They are all mounted in the piping above the heater, and no home is piped so you can have two temperatures of water to the appliances and faucets. The drawing is inaccurate in that the ball valve water control goes on the line to the heater, not the one to the mixing valve. If you read the installation instructions the last line states that "these valves should never be used for anti-scald or anti-chill functions".
JerryR
Active Member
Florida
Thanks to all for the replies.
I ordered a WATTS 1170.
It has a wider temp range than the 70A as "it can be set to any temperature between 90°F and 160°F with flow rates as low as 0.5 gpm and as high as 23 gpm." Seems it comes preset to 120 dF output.
My dishwasher has its own heater elements and washer seems to do fine at 120 dF hot water so all feeds will get 120 deg tempered water.
I think at first I will install it with the existing 10 year old 40 gallon WH and see how it goes. I can always replace it with a 50 gallon GE tank later. The WH is installed in a very open area in the garage so replacing it, if needed later, will be easy.
I’ll report back after installation.
Jerry
Winslow
Hawaii
If you turn the temp up too high you will have problems with the T&P tripping, 140 sounds kinda close.
JerryR
Active Member
Florida
Jerry
First, THANKS TO ALL WHO REPLIED.
Update:
I installed a new 6 year, GE, 50 gal, 4500 watt heater with a Watts 1170 tempering valve today. I bought the heater from HD store. List price $267 less 10% disabled veteran discount.
I bought the Watts 1170 tempering valve online for $86.69. It cost a few dollars more than a 70A but I like the fact that if it fails it would be an easy R&R, being that it is attached with 3 unions.
All water pipeing was done with sweated 3/4" hard copper and a Watts ball valve for cold shut off. I reused the CPVC that was attached to the T&P valve.
I bolted the 1170 tempering valve, via it's union, directly to the dielectric nipple on the hot exit of the water heater, not as per Watt's instructions. We will see if it survives in that position.
I set the water heater elements to 140 dF and left the tempering valve at factory settings. Tempered water is exiting the faucets at 116 deg.
I am relaxing in bed, typing this on my iPad! after just taking a very nice hot bath in the roman tub, and for once I dd not run out of hot water.
I like when things work out.
Jerry
JerryR
Active Member
Florida
Here is a picture of the final installation.
Jerry
JerryR
Active Member
Florida
Update
Last night I filled the roman tub and took a nice warm bath. After I got out of the tub and drained it my wife decided to take a bath. The 50 gallon heater set at 140 df with the tempering valve set at 120 dF filled the tub twice and never ran out of hot water. Amazing.
Jerry
Young_apprentice
The CAPE
Huh interesting Im thinking about maybe throwing one of those onto my WH at my house. How did this Tempering Valve allow you to have more hot water? For two baths thats pretty good for an electric heater. Now isn't running you WH at 140 going to add to your electric bill as you now have to maintain a hotter temperature? I would think the heat traps would be a really good idea to prevent the hot water rising up the cold lines
JerryR
Active Member
Florida
With a Tempering valve you set the water heater temp up (140d) and the valve mixes the Hot water with cold to provide a tempered hot water (120d) to the house branch. This essentially gives you more capacity. My 50 gallon heater set at 140d provides enough hot water to fill the roman tub twice, same as a 75 gallon heater set to 120d.
The cost to maintain the additional 20d to 140d water is negligible. Once the heater is up to temp the only variable is standby heat loss. Most new water heaters are very well insulated so standby heat loss is minimal.
The GE heater I bought came with pre installed nipples with heat traps. Additionally if you look at my installation the ball valve is installed about 10" above the feed and tank entrance. Feeling the pipes they remain cool.
I have a 7 year old grandson. I can crank up the water heater to 140d and set the tempering valve to 120d and not worry about scalding the child in the bath. Warm bath water is 105d when full.
Jerry
MikePlummer
Ontario, Canada
www.facebook.com
Here we have to install these on all water heaters by code. the one i use is made by Cash Acme and can have internal check valves to prevent heat migration.
JerryR
Active Member
Florida
Jerry
Reporting back about 8 months later.
The watts tempering valve intermittently fails to temper the hot water. One day it works fine, next day you have to crank in lots of cold water when taking a shower or it gets real hot. Measured Hot water temp jumps to 135df at faucet occasionally. Next day it measures 118df.
As you can see the watts was installed without a trap. I am thinking that this has caused the problem.
The Honeywell AM101 advertises that a trap is not needed. I am considering replacing the Watts with a Honeywell AM1 series.
Question I have, does anyone know if they are interchangeable i.e. same form factor and just undo the unions of the Watts and bolt the Honeywell to the same unions?
Jerry
It's rare when even the same model after time uses the same form factor...it happens, but I think you'd be lucky. At less than a year, I'd be calling the manufacturer and let them know...it should last years, not months. Mine's about 6-years old and still doing its job.
JerryR
Active Member
Florida
Yup, I was going to call them but when I found the number it was after 430 eastern, after they closed for the day. I'll call them tomorrow.
I looked up the warranty and it said to send it in for repair. Not realistic. If I remove it I'll replace it with some other model/manufacture. That's why I asked about the Honeywell model. The Honeywell AM101 instructions state it does not need to be trapped. If the Honeywell doesn't just bolt on it's not that big of a deal to break out the torch and just redo the copper.
For now I'll crank the heater thermostats down to 120df until I get a new valve. Home depot sells the Honeywell valve but it has to be special ordered. I'll probably just mail order one.
Jerry
