Gusherb94
So i have a question that I thought you could answer since your a chicago plumber and i assume are familiar with type of building i'm describing it's a early 1900s three story brick building with the first floor being a storefront and the top two floors apts it's on halsted in the bridgeport neighborhood and my question is about the original plumbing setup right now there's a 6" sewer line that runs the perimeter of the basement wall and goes straight into the sewer but the original line that ran under the floor went a slightly detoured route instead of going straight into the sewer it goes into a 4' deep pit in the floor and from another pipe so does the floor drain/storm water drain line and then they both went out a third pipe which was the city sewer which is now plugged and the pit is now used as a sump pit with a sump pump and the only water that goes into it now is just storm water from around the building and the bsmnt floor drains. I was in the basement of another building and it had the same setup as ours (theirs was still in use too) which would lead me to believe that most of the bldgs on the block were done that way. Im guessing you or someone else on here has seen this kind of setup before and might have an idea why it was done this way.
thanks for any answers in advance.
Jonathan
Jonathan
