Scup
Somewhere, probably in a box store, I purchased a bunch of Zurn Pex fittings including elbows and adapters. I went to the Pex system since I have had very few problems over the years with my copper piping after my PH neutralizer tank, but before the PH tank my copper plumbing had routine leaks. Thinking that the Pex system would resolve my minor acid water worries, I purchased the tools and accessories i.e. those black looking solid copper compression rings and the ring compression tools to do the job and started to replace my front end piping. Now one of the pex fittings is starting to drip.
I am aware there is, or was, some sort of the class action lawsuit in which Zurn Pex claimed to be faultless regarding some of their fittings, but my position is I just wish to go about getting the front end of my piping squared away.
I love the PEX system and wish my whole home had such and intend to remain with it. It is a joy to work with and seems to be almost idiot proof. However, I never thought this system would be subject to leaking so soon. I noted that there are plastic pex elbows, and I even tried one and it worked out well. Probably plastic is not a good idea in a indoor plumbing scheme since plastic is subject to failure if hit with something, but in my case, nobody could easily get under the basement stairs where the tank is even if they wanted to. Not too happy either wondering if some of my fittings could suddenly fail without warning.
My simple question is what fittings (brand) do you guys use with pex piping and would they be compatible with the tools I currently own?
