dyihomer
- Messages
- 3
- Reaction score
- 0
- Points
- 0
Hi,
We have a house that uses a boiler and basebords for heating, it has 5 zones, and a 1/25 hp circulation pump (the house is around 3000 sqft). Every time the heat starts up, we can hear popping noises.
The other day we called a plumber comes to fix the noise in the baseboards, saying that the noise is from air bubbles. So he bled the system and guaranteed that he could remove all the air and the the heating wouldn't make popping noises anymore because it will be completely filled with water and no air. A few days later, the heating was still making the noises (a bit less than before but still loud), so we called him back, this time he says that we need to buy an additional part to filter out the air bubbles, and additionally there's steam making noise because the hot water is moving too slowly because our pump is smaller than it should be and doesn't have the power to move the water. And after asking some more questions, he says that the steam is like air making noise, and that because the house is big and has 5 zones, the elbows will trap air inside that we can't get out without buying a filter and a larger pump. So, he wants to replace the pump we currently have with one that is about 1.5-2cu ft in size and he wants to add a filter, saying that he guarantees that the noises will stop after replacing both parts.
However, the pump in our house was replaced less than a year ago, by a different plumber. That plumber said that the circulation pump he installed is the right size for this size of house.
Since we don't know much about plumbing we are lost as to what actually needs to be fixed and how to do it!
Any suggestions or advice will be greatly appreciated!
BTW, both plumbers are licensed and have been in business more than 10 years.
