Vern Moore
I moved into an older home a couple years ago and have started to rewire different portions of the house. In the basement I have two junction boxes that provide power to plugs on the 1st story but also have low voltage wire connected in the wire nuts. I followed the wires back and they are connected to two zone valves on my boiler system. The remaining 4 zone valves have jumpers from valve to valve. There are only two low voltage wires connected to the boiler from the zone valves so I assume these are to call for heat. This is a newer utica boiler with honeywell v804 3f 1036 zone valves. I am not sure how to proceed with my other wiring because I cannot find anything that says these valves should be wired to 110v circuits. Any help is appreciated.
