Coastal2022
Good morning, my York central AC unit is leaking at the condensate pan. I have tested the operation of the condensate pump on the floor and its working, so I suspect that either the 1) PVC drain line is clogged or 2) There is an issue with the condensate pan under the A coil, potentially blocking water flow down the condensate line. Or both.
2 questions:
1. How do I access the condensate pan - do I remove the hex sheet metal screws on the face of the panel and then it pops off?
2. The installer of the condensate line did not leave me a clean out anywhere in the 3/4 PVC that runs to the condensate pump. Should I re-do the PVC add a clean out?
Thanks! Ted
2 questions:
Thanks! Ted
