AlGreen
Our 9-year-old gas heater just started leaking, so it's time. Looking for the regular tank type, capacity for 2-4 people, good energy efficiency, and willing to spend up to $1500.
The number of people doesn't indicate the size of the tubs or the number of simultaneous showers might be happening. A big soaker tub needs more water heater than a standard tub, a house with three full bathrooms needs more water heater than a single bath.
How big is the failing tank? Did it serve your needs?
Do you heat your house with a boiler? (An indirect fired water heater heated by the boiler has lower standby loss than a standalone, and the extra load yields a higher as-used AFUE on the boiler.)
It can a mixed blessing from the point of view of the WH. The deposits of hard water can actually make a protective coating. But the coating can build big enough to insulate the water from the heat source, especially with gas. The deposits can even displace water.I think filtered and softened water is good for your water heater.
Not a bad choice. The main thing is that you have hot water now.
What did you pay for installation and what was included in it?
