Glenn Wiltse
Hey, I bought and installed a Fleck dual tank setup about 18 years ago, it served me well until about 6 months ago. One of the valves got jammed , the gears started slipping, etc... I tore it all apart, had thoughts of rebuilding it , to try save some money, etc... but I still don't know for sure what got stuck in the valve, it looked like plastic, possibly from ... well I'm not sure where it came from. So, anyway, I'm leery about putting a new valve/control unit on my current tanks, for fear that the outlet tube's filter thing at the bottom has broken pieces.
So anyway, I'm weighting the idea of just buying enough new parts to make the same basic dual tank setup work again, vs just buying a whole new system ( to make my life easier ).
Currently I don't even know my hardness levels ( I forgot what they were when I specked out the original system. ( the number 20 comes to mind ). I know originally, I had a lot of iron in my water, but visually it seems I do have less iron now for some reason ( the well is 20 years old at this point in time ). I can and/or will gather this hardness and/iron information soon.. but for now, I'm just trying to understand if I should go with another Fleck 9000, or maybe a 9100... SXT or not... Or... are their better options out there now, 18 years later ? Part of me wants to use the same valve, because there would be no real plumbing involved, just connect the current disconnect/bypass to the new system and go... But then, if there's some real advantage to going with a newer system/control valve, I would consider doing a whole new connection to a new softener setup...
My house is 4 bed, 3 full baths, one of the tubs is 100 gallon, and when used, at least 50 gallons are put in it, through a 10 GPM faucet. This large tub doesn't get used nearly as much as it used to, but I still would like a system that's fully capable of filling that tub up with 70 gallons of water a couple times a week or more. With three full grown humans in the house, there's typical laundry , shower, and other needs going on in a daily basis. Some members of the home are up till 2AM , other members are waking at 5 AM...
Other information... I run a reverse Osmosis / RO filter for drinking water. We can't stand drinking soften water, and for other reasons, we prefer having the highly filtered drinking water.
So, give me some advice... what's my best choice for replacing my old/broken setup? Is there something else I should be thinking about, or doing to make sure I get a good setup that can last me another 18 years or more?
