hexe
Searched the archives, but didn't find anything that quite fit what I'm seeking...
I'm renting a place that is presently set up to have the washing machine discharge directly into a vertical pipe, around 18 inches in length, which is situated about 6 feet above the floor of the basement/garage [the house if a raised rancher]. I have two German Shepherd Dogs who are always happy to share their fur everywhere, so I've always made sure I had a really fine-mesh drain screen set in the utility sink where my washing machines always drained out...but this place has no such sink, and I'm not convinced that the mesh sock on the discharge hose that's hung in the vertical pipe will collect all the dog hair, lint and other debris carried out when the washer empties.
I can't make any permanent modifications to the existing plumbing, since I'm just a renter, so I was thinking I could just set up a utility sink that wouldn't have any water supply to it, and have the washer drain into the sink, so I can filter the discharge water so I'm not pushing all that dog hair and lint through the plumbing. The question is, how do I get the water that will then drain out of the sink up to that vertical pipe where the washer was formerly discharging? I'm guessing I need to have some sort of pump connected to the sink drain, and then run a hose from the pump to that pipe? I don't want to spend a fortune on this project, since I've only got a year's lease...
Thanks in advance, and hope my description makes sense. Will see if I can't get a sufficiently-lighted photo of what is presently there...
