Hello all, have been lurking for answers to some of my problems and I've picked up some great info so far, so thank you for that.
I moved into my house in June 2017. On a "mountain," tons and tons of HARD rock. They had a hell of a time hammering out the foundation. Drilled well, 650', original well report stated a 6GPM flow.
My original setup was a 2HP 3-phase motor/pump set at 500'. In the control box, i have a Schneider Electric model ATV312HU15M2 drive which supplies power to the motor. 60/40 pressure switch with a pressure tank (cant remember the size, but its not that big.)
So, we had problems with running out of water. I don't irrigate, wash cars, anything that would be considered wasteful. Well pump would shut off on low pressure, we let it sit overnight, and would have some more water in the morning, only to run out again very quickly.
So we added some cisterns in the basement. 3/300 gallon tanks (900 total). The well pump fills the cisterns by use of a float switch, but it is not wired directly into the drive. What we did was add a solenoid valve after the pressure tank. Float switch would lower, open the solenoid valve, pump would turn on once pressure dropped, and fill until the float switch told the solenoid vale to close, pressure would build up to 60psi and the pump would ramp down. This worked for a few months until I noticed the pump shutting down on low pressure.
Next attempt was to lower the pump, with hopes that the additional storage in the well plus the cisterns would be enough. This proved to be untrue. We lowered the pump to 640', only the have the same low pressure after a week or so. I verified water levels in the well by using an Eno Science well sounder.
My recharge rate had dropped to 0.05GPM
No, not half a gallon a minute.
1/20th of a GPM. Completely unsustainable. I've gotten by with hauling water in an IBC tank from my parents house across town (on city water) and filling my cisterns every few days.
At this point I bit the bullet and gambled with drilling deeper. The drillers went from 650' to 905'. They hit new rock formations, which is promising, and claim the well now makes 10GPM which is more than i ever hoped for.
Here's my question. I still want to use my cisterns, but I do not want my 3-phase pump motor to operate on pressure anymore. I have to keep adjusting the ball valve to restrict some of the water flow so the pump doesnt shut down on low pressure. It seems like more of a temporary fix.
How can I get this 3-phase variable speed pump to operate with just the float switch alone?
What kind of safeties can i use for a low-water situation?
Am I better off switching to a single phase setup with a cycle-stop?
I am not worried about pumping from the cistern to the house, that setup is working perfectly (DAB E.SYBOX)
Thanks for any and all help, let me know if any more info is needed.
