Hi there,
I'm wondering if anyone can confirm that a Vespin II will fit with this 14" rough in toilet in my 100 year old home. The water valve at its innermost edge on the handle is 6-1/8" from the centerline of the toilet, which is less than the 8" that was recommended but I read on this forum that 5.5" from center should work. (Hopefully the valve will be able to open and close without the handle hitting but maybe there are smaller handles I can use?)
The part I'm not sure about is that the way the pipe comes in with its center at 13.5" from the floor and then drops down to 8" where the valve is. The valve comes out 6.5 as measured from the wall. I'm attaching an image below, but my main question is if there is anything I should worry about here, or if I have a good shot at it fitting. I'll plan to buy the 14" unfit tube along with the Vespin II. Thank you!
