mappley811
I'm installing a light/vent/heater combo in a new bathroom, and I'm looking for some guidance on the proper (code-compliant) way to wire it so that each of the three functions is on its own switch. I'm going to install it on a dedicated 20A circuit per the manufacturers instructions, and will be running 12/2 from the panel to the switch box. The way I see it, from there I have basically three options:
1. Run 12/4 from the switch box to the unit, using each of the three hots (red, black, and blue) for each function of the unit. This makes the most sense to me, but I see a lot of talk that /4 wire is intended for 3-phase applications, so I'm not positive if this would be code-compliant.
2. Same as 1, but use 12/2/2. I don't think this is the way to go, because while it's the same wire as 12/4, it's color-coded with a white/red instead of a blue, which I think means it's intended to be used as a second neutral. I think it would not be kosher to use the white/red as a hot.
3. Run 12/3 to the light and vent, and then a separate 12/2 for the heater. I would wire nut the neutrals together in the vent unit's junction box, connect them to the unit's neutral with a pigtail, and connect both neutral to the neutral from the 12/2 in the switch box. Is it legal to have the unit's neutral to be using 2 neutral wires between the unit and switch box?
Thanks for any guidance!
Edit: I don't think it will matter, but I'm in Connecticut and doing the electrical myself under a homeowner's electrical permit.
