Sparknzapper
Hello all! I searched the forum and only found something similar, but not close enough to apply.
I wish to wire up my Leviton Cat. 5226 Single pole switch w/pilot lamp to a swimming pool lamp.
These lamps typically don’t last very long. Therefore, it is my wish to wire up the circuit NOT to show by the pilot illuminating that the circuit is energized going to the lamp but rather, I wish for the pilot lamp to only illuminate when the lamp is lit only . In other words, if the pool lamp blows out while the circuit continues being energized, I wish for the pilot lamp to go out with it. As said, being that these lamps never last very long, merely showing that the circuit is energized is not nearly as helpful as the pilot showing the bulb status. If only Leviton provided a schematic or diagram of the switch terminal layout, I wouldn’t need to be asking this. Keep in mind that the pilot lamp inside the switch is a neon type bulb and has no filiment. Connectivity therefore cannot be done using series wiring by the neutral coming back to the switch box from the pool lamp to feed power to the pilot lamp.
My apologies for the length of this post, but I wanted to spare us time from trying methods that have already been tried and will not work. An electrician explained this solution to me once ago and I did copy it down, however due to my wife’s extremely zealous cleaning habits in conjunction with it being written on a paper napkin, it’s pretty much decomposed several feet below ground by now. I did at least inform her about napkins with writings on it; as some of the worlds greatest inventions began this way.
Anyone have the savvy that this electrician once had shown me?
With greatest confidence, I thank all who make up this forum!
Pete
Pete
