stardog
Reporter
Our home was built in the early 1960's and consequently still has much of the old wiring (2-prong receptacles, not 12-2 or 14-2 conduit as is used today). All of it is still in good shape. Over the years I have been able to upgrade some of the circuits to current code as I complete various interior remodeling projects around the house.
I have a single ceiling light in the hallway, controlled by two switches, that is still on an "old wire" circuit. I want to replace this ceiling fixture with two 4" recessed LED lights (strung together), with one dimmer switch (the second light switch will be removed from the circuit and no longer used).
Although knowledgeable, I am not an electrician. I was advised by someone with electrical experience that installing the recessed LED's, along with a dimmer switch, without upgrading the conduit to 12-2 is not a good idea and may not meet code. Something to do with potential grounding issues. I had never thought of this being an issue until now.
Does anyone know if this is true? That I need to upgrade the circuit that the current ceiling fixture is on to 12-2 (or alternatively create a separate 12-2 circuit for the LED's), before installing the recessed lights? What I assumed would be a simple swap out of ceiling lights now has me seeing $$$$ in the event I have to first upgrade the wiring. Many thanks for anyone's input on this.
