aaabbb
I need some advice on winterizing a vacant home that is currently being renovated. I plan on keeping the heat on since contractors will be working on the home periodically during the day but I would like to turn the water off whenever water isn't needed for peace of mind. Since I am leaving the heat on, do I need to blow out the lines after turning the water off, or would opening up each faucet and purging them of water be sufficient? I also need to know what to do with the gas water heater. Does the water heater need to be turned off and drained, or would putting it in "vacation mode" be sufficient? I also have a question about the toilets. Is there any reason why I would need to put antifreeze in the toilets if I'm leaving the heat on? Since I have a septic tank, I really don't want to flush antifreeze into the system each time I have to turn the water back on. I have a freeze alarm on site so I seriously doubt that the temperature in the house will ever go down low enough to freeze the water in the toilets.
Temperatures have been dipping down into the teens at night so I really think winterizing the house will give me some peace of mind. Any advice would be appreciated. Thanks.
