Window AC into through wall ?
Mar3232
Indiana
Don't you think that if I left plenty of clearance on the sides of a window unit, I could use it as a through wall AC?
I have a metalworking shop, so I could easily build a sleeve that would make a tight fit on the height but on the width was thinking maybe 6" (or more?) space for the side vents. It's for a small bedroom (only 225 sq feet). I was thinking about one of those mini units.
Also -- is Haier junk?
Cacher_Chick
Test, Don't Guess!
Assuming you have 2x4 stick built framing, some window units will fit with the vents are spaced out enough so that they will be outside.
As for brand, I think they are all junk these days.
Mar3232
Indiana
It's a cinder block wall plus 2x4 so pretty deep. I would think it will be ok? -- I plan on one of those mini units, 6000 btu.
Dana
In the trades
It's more money, (and oversized for the likely load, as is a 6000 BTU window-shaker)) but a 3/4 ton modulating 115V "inverter drive" mini-splitlike a Gree Rio would be quieter and more comfortable delivering more stable room temps, and puts only a 3" hole in the wall. If you have 220-240VAC circuit avaiable you could do even better with a 3/4 ton LG.
