I have an old CST744SG 1.6gpf Toto Drake. Recently I had a problem when I changed out the supply line (which was leaking). Old line did not want to come off and the tank moved. It has since started leaking from the gasket between bowl and tank. It could need to be re-aligned or the gasket might need to be replaced, but if the tank cracked, I want to know what tank to get to replace it if necessary. While researching I noticed the 1.28 tanks and was wondering if the ST743E would work.
I was comparing the eco toilet to the one I have and noticed they use the same flush levers, flush valves, same gaskets, same trip levers, same fill valves, etc but the drain valve is different (which I assume is to control water flow). The tanks have the same dimensions as well. Is it basically the same tank as the ST743S?
From my understanding the S line of bowls are discontinued and the E bowls are now in use. Not sure if there are any physical differences or if they just changed a letter for marketing purposes. I saw a similar question from 2009 but it didn't completely answer my question & I want to make sure.
I'm really hoping it is just the gasket, but I'd like to know just in case.
