Jmacinnes
Hi there! Hoping for some guidance on planning a filtration system for my off-grid well.
My goal is to run the well pump once every couple of months or so (via generator) to fill a large tank with filtered water. Since I'll only be running the pump while filling the tank and can keep the lines fully open, I hadn't planned for a pressure tank/switch of any kind. However, if I put a couple of filters (maybe a 2-stage filter for sediment and carbon?) in between the pump and tank, will that reduce water flow in a way that would damage the pump? I know it's important not to deadhead the pump by closing the line entirely, so it seems reasonable that restricting the flow could have a negative effect as well. True?
Thanks, I'd greatly appreciate any advice you could share!
