Wilkins 975xl Flow/Pressure Issues
dblackburn
Pennsylvania
I have a Wilkins 975xl backflow preventer. It is removed every winter and passes its test before every spring. That said - my sprinkle output is very weak. Each time I run the sprinklers I have to shut off the water coming from the Wilkins and open the three relief valves. This can be done in any order - once all three are open - I shut them off one at a time - open the water valve back up - and my sprinklers run just fine.....
Once done all 5 zones run normally. There are no visible leaves from the preventer.
Thoughts?
Has it always done this? I have a Wilkins BF also, not sure of the model #, but your description is quite similar to mine, and I have never had this problem. I will be following this thread to see if there you get an answer to your question.
