Kev123
Hello,
I just recently had the pressure regulator replace (30 - 50 psi). And all was working fine. Then the pump started cycling(every 5 seconds) when watering lawn. I went to check the pressure tank. When I did water was coming out of valve. So I replaced the pressure tank(set to 28 psi prior to install) and ran the sprinkler system. All zones ran great (no cycling). But now it seems to be doing the same as before. It pegs at 50 and then runs and drops quickly to 30 and cycles (every 5 seconds).
What should I do to try and isolate the issue?
Thanks,
Kev
Thanks,
Kev
