Why don't kitchen sinks have trip lever/plunger drains?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by AndrewP, Feb 12, 2019.
  1. AndrewP
    AndrewP New Member
    Jan 20, 2019
    UK
    I've seen many sinks plumbed where one waste pipe has a sharp 90 that drains into the waste of the other sink. I know it's best to have the least amount of pipe before the p trap, but this is fairly common.
    Just wondered why I've never seen a bathtub style trip lever/plunger drain or standing waste applied to a kitchen sink. Would seem very useful when you want to drain a sink with filthy water as it saves having to put your hands into the water.Something like this:
    Is there a reason why?
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    I suspect the linkage could get impacted with food waste. A bathtub drain deals with hair, but not food residue.
  4. jadnashua
  5. hj
    My sink DOES have remote operated drains. You just need holes in the sink for the push/pull knobs.
  6. AndrewP
    AndrewP New Member
    Jan 20, 2019
    UK
    Those commercial ones linked to I think are butterfly valves. Interesting design, that would impede water-flow less than the pop-up ones you get on bathroom sinks. These seem to clog all the time.
    Hj, what method does yours use?
    On clogging, the standing waste design, would seem the least likely to clog in theory.
    Which of these would work better? The first is pretty standard standing waste, with p-trap. The second attempts to reduce the exposed pipework. These are not to scale. Basically the difference is the bottom of the second waste/overflow (in brown) is underwater. Any thoughts?
  7. Sylvan
    Sylvan Still learning
    Sep 23, 2004
    plumbing - fire suppression - boiler inspector
    New York
    We install hundreds of Franklin wastes Unfortunately many are now imported and are crap
  8. hj
    Mine are cable operated with push/pull knobs on the sink deck. My sink has six holes so it has the faucet, steaning hot, cold drinking water, two drain operators, and a soap dispenser.
  9. Sylvan
    Sep 23, 2004
    New York
    Notice the cap on the Franklin opposite the handle? That is for an overflow if the sink has one
    The problem with an overflow on kitchen sink overflow is the possibility of bacteria growing near food preparation
    This is why expert witness can work the legal system on both sides either way you're doomed if you have to defend an action in court
    No overflow a good chance of spillage causing a fall , with a overflow great change of E - coli
  10. hj
    ALL "expert witnesses" have to check who they are working for because they ALL can work for either side.
Similar Threads: don't kitchen
Plumbing Forum, Professional & DIY Advice Don't dump coffee down the kitchen sink while the disposer is being replaced. Jul 5, 2013
Plumbing Forum, Professional & DIY Advice Installed new kitchen sink and water lines don't reach now, need to get an extension Sep 29, 2012
Plumbing Forum, Professional & DIY Advice Don't run out to the hardware store that fast to fix a plumbing problem. Apr 3, 2020
Plumbing Forum, Professional & DIY Advice YP.COM Scam Yellowpages.com Scam, Don't sign up with this company! Jan 22, 2020
Plumbing Forum, Professional & DIY Advice When you kiss your girl, don't talk about plumbing Dec 29, 2019
