Great forum, thanks for any advice...
So about a week ago I noticed that my tap water no longer had that silky feeling and using my Sofchek test strips it was reading about the 250 ppm.
I have cleaned out the brine tank and refilled with new Mortons System Saver.
I verified that my Fleck 5600 valve is filling the brine tank and drawing brine during the regeneration cycles. I took out the injectors and screen and cleaned them with a toothbrush but they didn't have any build up on them.
Today I changed the resin and replaced the distributor tube and lower basket as it had a slight crack in it. After reassembling everything and backwashing then putting it back in service, I still have hard water the same 250 ppm reading. The water doesn't have that silky feel to it. Yes the bypass valve is set properly.
Is there anything else I should do? There is a piston rebuild kit that has the seals, spacers and brine valve that I can get on Amazon but I don't know if it could be something else and may just have to bite the bullet and call a tech to come look at it. Is there anything else that can be checked or done or should I just call for a tech?
Thanks again.
Thanks again.
