Miles McCoy
Hello! This is my first post and my first plumbing project. I’m using PEX to install an ISpring 2 stage whole house filter. Access to my copper pipe is in the crawl space. I need to build a mount to attach my filter to. My original plan was to position the filter so that water flow would remain in a straight line like it already is and to have my bypass line go above or below the filter.. But with the amount of space I have it would be easier to have my bypass line be in a straight line and my filter to be below that straight line so that everyday water flow will now have to take an extra 4 90 degree turns to get through the filter and back to the original water line. Will this effect my water pressure? Will this potentially cause leaks? Thank you for your time!
