Taylorjm
Active Member
So when servicing my well system and adding a shut off valve, I noticed that the galvanized pipe that was used to setup the pressure tank, switch, gauge and boiler drain valve had a white residue inside it. It wasn't a crusty buildup, just a thin layer and I could wipe it with my finger and it would coat my finger as well. This is before the water softener and I have very hard water, 65 gpg of hardness. So any idea what the white residue is? Is it just because of the hard water or is it something unique to the galvanized pipe? I'm pretty sure it isn't inside any of the copper after the water softener but I don't know if it's on the copper before the water softener. Just wanted to make sure it's not something related to the galvanized pipe as this is the only galvanized in the entire system. Mineral buildup from the hard water? Does it accumulate only on galvanized or any kind of piping?
