Koa
Given a choice which slot do you prefer to use in the flange. This is a non-swiveling all ABS (I know some perfer the metal ring ones) that is not glued in yet. One slot is through diameter to outside the other runs parallel to circumference.
I notice that the brass toilet bolts are free to rotated under the flange. So generally you hold the threaded part to tighten? Thank you.
