Bob NH
If you wanted to use home runs you could simply make up an assembly of tees; probably with 3/4" CPVC. You could probably get 3/4" tees with 1/2" branch outlets, install a 1/2" ball valve on each, and run the line to each service point.
The advantage of a manifold and home runs with PEX is that it eliminates a lot of connected tee fittings. Tee fittings are not a big cost or problem with CPVC so there is little to be gained with a manifold and home runs.
I would probably run a main line in the direction of the kitchen and bathroom and then branch off to the fixtures as required.
