northcoast
We need a new softener as our old Culligan Mark 89 is leaking at the control box. Hubby willing to install a new one but knows nothing about softeners. I am getting confused with all the info on the internet. We are not tied to regenerating once/wk like most seem to recommend. So here's our info:
-On a well
-3 reside full time in house, 4th is home from college on breaks & summer.
-no idea on usage as I can't see a meter on the softener
-Water hardness is 20 gpg
-Iron is 2.09 mg/l
Ohio Pure Water suggested a 5600SXT, 64,000 grain capacity, 2.0 cu ft resin. I asked if we could get a 48,000 grain capacity with 1.5 cu ft resin and regenerate more often. I was told yes it would work but careful changing the salt setting as it may not clean all the resin? Does that make any sense? I saw info on Aquatell site but I don't know if it's correct or how to use that info.
I have looked at other threads but I don't know/understand all the lingo/settings.
Currently our Culligan softener is set at 10 lb salt/cycle, probably going 3 times/wk depending on laundry loads. We could love to be as efficient as possible with salt.
Thank you for your help!
-On a well
-Iron is 2.09 mg/l
