Kadip
Hi- I am installing a new tub. The manufacturers drain pipe assembly (black) is threaded on the bottom end and the waste pipe in the floor (white) is also threaded. The drain pipe assembly in the pic has about 3in of pipe extended down into the waste pipe in this photo. Not visible. Pic attached. What type of connector should I use to connect these 2 pipes? I will have limited room so careful not to add more than about 3/4 of height with any connector. Many thanks for your advice.
