Which Clack Valve and filter setup?
Offguard-2
CA
I'm trying to decide among these options:
Option 1 - CWS125 - 1 tank with combined filtration media - 1.5 cu ft
Option 2 - CWS125 - 2 tanks, 1 valve - filtration media tank after softner - 1.5 cu ft
Option 3 - CWS125 - 2 tanks , 2 valves backwashing media tank before softner - 1.5 cu ft
Family of 4 with average use of 200 GPD (city water). Water hardness of 15 and Chloramines 2.36 ppm.
The price of each system steps up in price. Are there any reasons to avoid any of these options or is it mostly based on budget? It feels like a Good, Better, Best scenario.
ditttohead
Water systems designer, R&D
Ontario California
Option 3 will give you the best results... option 1 is worthless unless the medias are properly separated with a vortech midplate, option 2 eliminates the backwash valve on the carbon, not a particularly good idea.
Offguard-2
CA
Thank you, dittohead. Do you know if the
With option 3, is 1.5 cu ft the right size? We use about 200 GPD. Hardess of 15.
Also, it looks like the Clack bypass is 1" on the WS125. I understand the valve t obe 1.25". Would the bypass adversely impact water flow?
ditttohead
Ontario California
The Ws125 and Ws1 re virtually identical, just the internal components are different, and the riser tube is larger. The bypass will not affect flow. It has more to do with velocity calculations than flow... the bypass can flow 50 GPM theoretically; velocity would be insane but...
Size is adequate for your application.
Offguard-2
CA
Would the WS1 offer an adequate performance in my situation or would you suggest the additional cost of the WS125? I wasn’t sure if that was implied by your first sentence about the comparison of internal components.
