Michael A DeMarco
Hello all, great forum you have here. I have been reading through all the posts in the to gain some beginners knowledge as to what I have on my property.
We bought an old farm, and built a house on it. I immediately noticed and realized the value of a 6" well casing sticking out of the ground, and built my house without damaging or disturbing it. I have almost run it over a few times in the meantime, but I am finally ready to start doing something with it.
The well was drilled in 1979, I attached the well log as it could interest some. The well is at 160' deep, and states 6 gpm.
My goals are to get this thing up and running, to use as my primary irrigation source for around 2 acres of landscaping: an acre of Kentucky bluegrass sod, planter strips with trees, and 1.5 acres of pasture grass, 12-16 zones(?)
I would ultimately like to remove the old well pump, electrical wire, and cable running down to it, and replace it all so I have years of reliability ahead of me.
A primary question to begin, my biggest concern is the well runs water out the top cap consistently. It is a trickle, but it is running. Where I live there are springs scattered around, I have one on my property, 200' from the well. It worries me that if I pull the cap to start pulling up the pump I could open up a larger stream of water, near my houses foundation that I can not stop easily or at all.
Reading around on the forum, most seem to indicate there water level is some feet above and below the well pump, not flowing from 160' down and up out of the cap. The springs should be at a shallower depth, and how would they be getting into the well pipe anyways at the lowest runoff time of the year, the fall?
Well, thanks for any advice, want to start out on the right foot!!
