James23912
So I have an older angle shower unit with the plastic walls I am installing and I was dry fitting it today. There is a pre drilled hole for the valve on the right hand side as you enter and I was assuming the shower head would go directly above it, but as I was standing in the thing I realized that while the hole is basically centered on that wall section the floor drain does not line up with it and when you are standing there your feet essentially straddle the drain hole so in effect the valve is to my right and the shower head would be aiming at my right shoulder so I am thinking I should run the head more to the corner, does this come up often? There’s not a whole lot of room in this thing.
also wondering if the half inch from valve to head is enough when you have two hall inch supply lines, I was reading about some issues with that.
