HomeownerTX
Hello all,
I'm in SE TX on a residential well. The water's fairly acidic and slightly hard, so I'm planning to install an acid neutralizer and water softener to cut down on the acidity and hardness.
My question is more related to general plumbing practices, and not so much related to the water softener and water-well. I'm looking to put pressure gauges before and after all of the filtering/water treatment equipment, so that I can check pressure drop and see when I need to clean/change the filters.
Planning to use 1" SCH40, and have some flex-lines (copper or stainless) to hook up to the water softener and acid neutralizer. The main reason for having so many ball valves/unions is to be able to isolate/easily remove lines if needed. This is all installed in a garage, if that matters.
Does anyone see any issue with putting the pressure gauges on the elbows (using tees), like I have shown in the picture? Also, would you do this set-up any differently?
