Mike McKinzie
I am planning on installing a tankless water heater in my attic. Where would you recommend that I run the condensation line and how much water will be coming through it. The drain for the A/C unit is right next to where I will install the water heater and it empties into a pipe which I believe leads to the sewer.
I seem to have two options. I can run pvc across the attic and outside or I can tie into the A/C drain. What would you recommend?
