Where should I mount rain indicator?
Discussion in 'Irrigation / Sprinkler Forum' started by CountryBumkin, Jan 15, 2016.
  1. CountryBumkin
    CountryBumkin Active Member
    Sep 4, 2009
    Orlando, FL
    I bought a Rain Bird "rain indicator" to shut off sprinkler system when its raining, but not sure where to mount it. It would be easiest to put on the side the house but then it would be under the roof soffit - so it probably wouldn't be catching any rain water.
    Can I attach it to the trunk of my Crepe Myrtle tree? Or does it need to be on a pole by itself?
  2. Smooky
    Smooky In the Trades
    Apr 4, 2011
    North Carolina
  4. CountryBumkin
    Sep 4, 2009
    Orlando, FL
    Thanks Smooky. I should have thought to go to Rain Bird website and look for instructions.
  5. hj
    hj Master Plumber
    Don't you have a fence you can mount it on?
  6. CountryBumkin
    Sep 4, 2009
    Orlando, FL
    I'm hoping to avoid running any wire underground - so I want to keep the device close to the side of the house. I'm thinking that I will mount it to the fascia board (I don't have gutters) of the house just below the roof drip-edge but on a bracket so it extends out enough to not get any roof run-off. Maybe 12 inches out. Then I can run the wire into the soffit and to my irrigation controller on the other side of the garage wall.
Similar Threads: Where should
Irrigation / Sprinkler Forum Where do I install sprinkler Pump Mar 14, 2021
Irrigation / Sprinkler Forum Two problems - controller leaking, underground pvc broken somewhere Apr 20, 2012
Irrigation / Sprinkler Forum Winterize Sprinkler, where to hook up Air Compressor? Oct 28, 2009
Irrigation / Sprinkler Forum New owner of home - where are the system lines?? Jun 22, 2008
Irrigation / Sprinkler Forum Zones not working - Where are the valves? Sep 3, 2007
