Donn2390
You solved my Toto problem last month, now I'm on to bigger and better things.
I have two standard builder grade toilets that I recently changed all of the parts in the tank. One had a slow leak, the other was the same age and looked grimy, so I replaced all the internal tank parts on both.
Both toilets are still leaking. I assume it has to be leaking at the flapper because there are no external leaks, no water on the floor, etc.
Our home has four bathrooms, two with Totos, two with the builder grade, installed around 2002. Two people live there so the two problem toilets are always turned off. I am now renting the home out so I want all four to work perfectly.
With the new internal parts installed, I fill the tank to the shut off point, and then turn off the valve. In a 24 hour period, the level will drop about an inch. Not very much, but more than I like to see.
I purchased the Fluidmaster kits which I assume are the gold standard. I am at a loss to figure out where and why I'm losing that water.
I live in the California desert, where water is precious and expensive, it's not uncommon to see water bills of several hundred dollars a month, 3-4 hundred dollar water bills are common, so every drop adds up.
I've been fighting this for weeks now, so discouraged I'm about to go buy two more Totos...!
Suggestions??
Thank you....
Suggestions??
Thank you....
