CountryBumkin
Active Member
My PVC toilet flange is broken and the repair ring did not work, so I cut of the flange flush with the tile and planned to ream out the old piece of PVC and weld in a new flange. The OD of the PVC flange is 4".
So I ordered a 4" reamer - and it just came in (after waiting a week).
But the actual OD of the Reamer is more like 4-1/2".
Where did I go wrong. Why doesn't a 4" reamer cut out a 4" hole?
I have a similar design reamer in 2" that I used on my Pool pvc and it works exactly as I expected this one to work. But the pilot or centering part of the reamer is 4" and cutter is more like 4-1/2".
What size reamer should I get? I need a reamer where the centering part fits inside the 4" flange (around 3-3/4" pilot) and it cuts a 4"OD hole.
Should I just try to chip or grind the old flange out - or would it be better to just the correct size/type reamer?
