vpn33
Quick backstory: I have a basement rambler and for the past several months, I have been noticing a faint odor in certain areas of the house that seemed to be originating somewhere under the stairs. I have switchback stairs with a landing going down to the basement and underneath is a storage area. When I open the folding door to under the stairs, it has a pretty strong smell which I determined has to be coming from the joist channels because they are exposed under there and I took everything out from underneath and found nothing. I originally thought it was a dead smell and was just waiting for it to go away but it has been there for probably 6 months and hasn't changed and the more I go in there, I think it is more of like a stagnant water/sewer smell.
Lately when I go outside the front door (in the picture), I occasionally get a sewage smell depending on the wind. Anyways, yesterday the dishwasher was running and I smelled it more and I leaned down to that vent under the window and could smell it coming from there. I get a pretty faint smell from that vent with no water running but when the water starts running, it comes on stronger. That vent is right beneath the floor level of the main floor so it must be venting the joist channels. The kitchen sink is centered under the window and you can see the roof vent and I know where the pipe is in the basement (it goes straight down inside the wall and into the floor) and from where I measured, it appears that it is a straight shot from the vent all the way down into the basement and the sink drain must go over horizontally into it somewhere (I have the yellow line drawn where I believe the drain pipe is likely run, the yellow circle above the hose bib would be where the drain goes into the wall in the undersink photo). I can definitely hear the water running well when I get down near that grate just like you would hear water running through a pipe in an exposed wall. Where could this smell be coming from? There can't be a leak in this pipe anywhere or else I would have water in the basement or at least leaking through the ceiling or walls down below. What are your thoughts?
