Paul Stephenson
I am considering replacing (with PEX) all of my home’s remaining indoor galvanized water supply lines (at least 40 and up to 95 years old, showing rust at threaded joints but not yet springing leaks) and the existing main valve (see picture). Not at this time planning to replace exterior buried water supply line (again somewhere between 40 and 95 yoa) which is copper as it exits street water meter, but unknown material where it enters below grade through concrete basement wall.
I need advice on where to stop replacing vintage pipe/fittings, and if the elbow needs to go how to connect new to old. Attached image shows the water supply line entering basement wall (bottom) through some slathered on waterproofing (again unknown material). The first plumbing visible on interior is a brass (bronze?) elbow. The elbow is then connected to the main gate valve (installed backwards, with drain on street side) through a short (galvanized) nipple.
What is the elbow? How is it likely attached to the exterior pipe? Should I replace the elbow or leave it in place and endeavor to unthread the short nipple and commence PEX immediately after the elbow? The closest thing I’ve found online is a radiator union elbow (not as I understand it an appropriate fitting for water supply).
Thanks in advance!
Thanks in advance!
