Hi! Thanks for letting me join! This looks like a good place to be with a lot of knowledgeable people. I've done a reasonable amount of research on water treatment and am now looking for a good water softener. I was planning to purchase online as kinetico, culligan and wolverine seem to be way overpriced. However, if you know a good dealer with reasonable prices I would be willing to purchase local (Southeast Michigan area).
I am currently single, but have a 2.5 bath family home and want to size it as such.
My water has about 9 grains of hardness per gallon.
I have hydrogen sulfide (low amount per test strip, but it does stink when I turn on the tap).
0.1ppm iron (I feel like this may be higher but that's what my last test indicated.)
I currently have a TIRM installed. It functions by oxidizing iron, sulfide, and manganese and then filtering the oxidized version out in the media. It seems to use a fair amount of water when backwashing and I have a 2.5x10 sediment filter. I don't think this is big enough to allow enough flow to properly backwash the TIRM unit.
I, also, have an RO for drinking water.
Questions if you can please help:
Do I need a water softener unit at 9 grains (I think it would help, the spotting is getting pretty bad, but the place I bought the TIRM from thinks it's not a big deal. I think it would help the life of the RO system as well)?
Do you know of a good online retailer or someone local to me which is southeast Michigan (the two I'm considering most are the genesis from discount water and matrix from us water supply)?
What unit and size would you suggest/where can I get one?
Should I upgrade to a 4.5x20 sediment filter?
Is the TIRM unit (I think it uses katalox) a good way to get hydrogen sulfide out of water? Is there a better alternative? (More for future reference or if this unit stops working, but it definitely has fixed the stinky water at this point).
Thank you!
Thank you!
