What TOTO dual flush to replace 11" American Standard?
Jim Hurd
media, pa
Toilet circa 1981. Probably a 12 inch toilet in an 11 inch spot, but would that work today if I purchased a 12 inch Toto? It seems like a 10 inch would not be supported by the wall, so if I had to use 10" would I be better with a single piece vs current two piece? This is contractor grade, original when house was built in 1981 if that helps. Nothing added to the wall, nothing fancy with the flange.
Are you measuring from the wall? The measurement that counts is where the tank is above. That would have been a 12" toilet there, so assuming you recheck the measurement above the floor mold and to the wall, I'm guessing you will see at least 11.5" there. If so, any of the 12" rough TOTO dual flush will work there. They need 11.5" from the wall to the center of the drain. You can also move the adapter out 3/8" of an inch if needed.
Jim Hurd
media, pa
That's showing 11 inches to the wall, not the molding. We don't have another .5" there, sadly.
First, except for a wall-mounted or floor mounted, rear-outlet toilet, none of the typical toilets need contact with the wall for support...they are designed to have a gap behind them for a couple of reasons:
- if it sweats, there can be at least some air circulation and it doesn't trap that moisture and harbor mold
- the production variations with any porcelain materials would make it tough if had to be up against the wall, severely limiting your choices
FWIW, there's usually enough slop in both the toilet flange and the toilet so that you can fudge it off of centered, sometimes by as much as 1/2". COnsider that the outlet of most toilets is a bit over 2", and the minimum opening in the toilet flange is 3", so the toilet can be moved slightly off center.
Jim Hurd
media, pa
So you think a 12 inch Toto Aquia IV would have enough slop so I should just get the easily available 12 inch? Or you are saying just order the 10" and it doesn't matter that there's a space, even if its a two piece?
Jim Hurd
media, pa
10 inch seems uncommon, dual flush not that common, the combination seems hard. I found Toto aquia CST412MF.10-01 at lowes.com, but its universal height.
Jim Hurd
media, pa
I don't know how to order one, but apparently the Kohler wellworth has dual flush, standard height, and 10 inch rough in. None of the online ordering systems seem to find it though.
Is it still true that all unifit toilets are tall/universal height?
As far as I know, yes.
FWIW, Most dining room chairs are higher than a comfort height toilet. Most people appreciate them, especially as they age which, I think, is why they are more common. The population is aging and getting taller. People usually sit in one of them far longer than on a toilet.
Jim Hurd
media, pa
Ok, my universal height haters relented, so if I buy the Aquia IV and a 10 inch unifit adapter, then we should be good to go?
Well, the Aquia doesn't use a Unifit, but yes, if you buy the 10" rough-in version, it should fit on your 11" rough, but stick out an extra 1". The only thing on any skirted toilet to consider is where your water supply shutoff valve is...the skirt is wider and sticks back further than an unskirted one. Having an extra inch will probably make it easier. You need to look at the specifications sheet which gives dimensions. It assumes a true 10" rough-in, so move everything forward an inch from what is indicated. Note, you can also cheat the toilet back a bit on the flange to minimize the gap if you want.
https://www.totousa.com/filemanager_uploads/product_assets/SS-01323_MW4463056CUMG.pdf
You could try buying the Aquia IV, which comes with the 12 inch Unifit. If you cannot make that work, you could then get the 1o inch Unifit.
This is a marked up picture of my using a 12 inch Unifit making my own mounting holes and not using the intended slots. I could have used a 12 or a 14. If you used a 1o, it could look like mine. But it seems to me that you could do a similar thing with a 12, and 12 is pretty much free and has next to no resale value. I had bought a 14, and ended up having a friend sell it for me on ebay. I took a loss on it, but not bad.
index.php
I stand corrected on the UniFit for the Aquia IV...most of the earlier ones did not use the adapter.
