What makes an LP gas grill "convertable" to natural gas?
HandyGary
So. CA
Why can't I take any, non specific LP gas grill and convert it to burn natural gas with only an orifice change?
Thank you for any ideas, advice.
Gary
Gsmith22
Active Member
Central NJ
i think you can do that as far as I am aware. Moved from a house with natural gas to one with LP (propane) and converted my clothes dryer from natural gas to propane with just an orifice change. My mom has an outdoor grill hooked up to her house's natural gas supply and not propane - again just an orifice change as grill was sold to use small LP can. Company that makes the dryer, grill, etc. would need to sell the appropriate orifice but otherwise I don't see why you can't do the switch.
I guess that would be a good question for your grill manufacture. I would say just because you can make something work might not mean you should. especialy with fire inside your home and against manufacture recomendation .
Gsmith22
Active Member
Central NJ
Some LP grills are sold saying "not convertable to natural gas."
then don't buy that grill if you want one that is convertible. I have converted both Maytag and LG dryers back and forth between natural gas and propane and I have converted Weber grills back and forth. Can't speak to any other brand specifics but those brands only required an orifice change and the different orifice was available from the maker
Plant.One
Just here for the Beer.
oakland county, MI
that probably means the oriface is just not replaceable - they probably drilled the oriface port into a solid assembly. save $ manufacturing vs having to thread a port for switchable orifices to attach to.
HandyGary
So. CA
I've done the conversion before with no problems. (LP to NG)
Recently I bought a grill that suited me perfectly. I'll include a photo of it. It had an all-aluminum body, thermometer, two burners, (I want indirect cooking for slow cook and the addition of some smoke wood.) The jets were removable, it was lightweight and was a table top style with flame reflectors and a one piece solid cast iron grill. Just what I wanted for my safe outdoor patio that is stucco walled and ceramic tile floor with no obstructions to fresh air, a ceramic topped table; also a water hose is right there.
I read the size on the jets and used a few internet charts to determine what size I needed. I had a drill on hand that was very close, so I drilled them.
The flames were beautiful, blue, with layers in them. The valves when turned to minimum wouldn't stay lit, so I established my new minimum setting. I was suspicious, but there were no yellow in the flames at any setting.
The problem was that they were so hot that I could never close the top or get a moderate heat. On the lowest setting with the lid closed the thermometer woulds soar to about 400ºF. I crossed checked the heat reading with another thermometer of known accuracy.
Where do you fellows think I may have gone wrong? Thank you for your replies so far and for the ones yet to come.
Gary
Features:
13,500 total BTU (2 x 6,750 BTU each burner)
262 Square Inches Total Grilling Area
Reliable Push-and-Turn Ignition
Heavy Duty Cast Aluminum Lid and Firebox
Uses Propane Gas. Tank Not Included
Plant.One
oakland county, MI
Close and the same are not equal. Fuel air mixtures need to be precise. That means the oriface size needs to be precise. Not close. Precise.
Even being off by a few thousandths in diameter could be enough % wise to not be functional anymore - especially at minimum delivery levels where the fuel side is going to be the weak point.
Likewise - if you wobble the hole while drilling... you can also unintentionally make things worse.
That's also only one part of the process. From what I can read the propane regulator also has to go as well.
As others have noted - you need to get ahold of someone at the mfg and talk to them about the process and what parts are needed to properly convert their product- if it's engineered to accommodate that kinda thing.
HandyGary
So. CA
Not in my case, orifice was replaceable. I gave a description of my problem above. Thanks for the idea.
HandyGary
So. CA
I was success ful before but this time not. See my case avove.
