wwhitney
Typical proper build up under an enclosed slab without utilities:
Undisturbed native soil
Coarse gravel layer--no fines--capillary break, flattening
Insulation if required
Vapor barrier, e.g. 6 mil plastic sheeting
Concrete
The practice of putting a layer on top of the vapor barrier is very bad and to be avoided.
Now with DWV in the mix, it should go in one of the first two layers. And you don't want rocks or gravel pressing on the pipe, when things settle or get compacted, a sharp corner could damage or penetrate the pipe. [You also don't want concrete to squeeze the pipe as it shrinks, so you wrap the region of pipe passing through the concrete with a layer of compressible foam.] Plus you don't want to leave voids under the pipe where the pipe ends up unsupported.
So if your native soil has rocks, or won't get well compacted under the pipe, then you use some sand to fill in and cover the pipe. Maybe just 1-2" over the pipe. When your pipe is in the gravel layer, you've got competing interests, as the sand would defeat the capillary break, but protecting the pipe wins out, so you use the sand. The sand also provides a clue to anyone excavating in the future that something is buried there.
Cheers, Wayne
Concrete
Cheers, Wayne
