What is the best bacteria additive to septic system.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by SergeFlorida, Sep 2, 2014.
  1. SergeFlorida
    SergeFlorida New Member
    Aug 23, 2014
    Just recently moved to new house with well water and septic system and I am trying to learn how both systems work. After finishing my well water softener I have a question about septic system. I am not sure what previous owner did to the system in terms of maintenance, but I read some info online that I need to put some bacteria once a month. My question is in title. I am getting different messages in terms of what is the best and some websites says do not use rid-x as it will damage bacteria balance and some says rid-x is the best choice. Can anyone share your personal experience in this area.
  2. Terry
    Aug 17, 2004
    I've always heard the Bio-Clean was the way to go with septics.
    [​IMG]
  4. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    The rid X dry is good , I quit using it when it came in liquid only.
    I use Yeast and sugar mixed in Warm beer. Real Home Brew, Grandpa's way.
    Never used the Bio-Clean, But it should work good.
    The most important thing on a septic take system, is to watch what you flush.
    Chemicals and some T-Paper can cause big problems.
    You do not want to plug things up or kill your Micro Orgasms. lol
    Good Luck.
  5. SergeFlorida
    Aug 23, 2014
    Yes, I understand this part about chemicals and I found a list of safe chemicals for septic system. It is very interesting recipe not only for the septic but also for other uses. I am afraid without right proportions it may blow my septic tank, LOL. Thanks again.
  6. beeje
    beeje New Member
    Dec 18, 2019
    westminster md
    When I first bought a property with a septic system in 1993 I took a class offered by the county and learned that you should not put anything in your septic system that did not come out of your body accept toilet paper. Still on septic following the same rules. Never had an issue. In fact the last tank pumper mentioned that this is the cleanest tank he has ever pumped out. Said it was well maintained. That was 7/2017. The prior pump out was in 2008.
    MASTERPLUMB777 likes this.
  7. Rotaris
    Rotaris If its not broke, fix it until it is!
    Mar 10, 2013
    Jack of all trades, master of none!
    Alberta,canada (North eh)
    The best thing is to eat some Chinese food! Please do not add anything. My best bud has been in septic field for 30 years!
  8. water pro
    water pro Active Member
    Nov 11, 2020
    syracuse
    I'm assuming, like many, you may be worried about the water softener damaging the microbes in your septic. Don't. water softener discharge is NOT harmful to septic. the only thing entering the septic is chloride and hardness (mainly calcium and manesium). Chloride is what's left over after detaching from NaCl. Chloride differs from chlorine in that it is NOT an oxidizer or a biocidal, as is chlorine.
  9. LLigetfa
    Feb 6, 2011
    Semi-Retired
    NW Ontario, Canada
    I disagree. Even if it was benign, it is an extra load on the system. If local laws permit it, then divert it as grey water. That is what I do however it is not benign as it killed several trees.
    As for my septic tank, I have never used any special additive and routinely go longer than a decade between pumping it.
  10. water pro
    Nov 11, 2020
    syracuse
    it kills plants for a completely separate reason. plants/trees survive by making chlorophyll. Chlorides and salts prevent a plants flow of potassium and magnesium, both of which are vital ingredients in the making of chlorophyll.
  11. taylorjm
    taylorjm Active Member
    Dec 18, 2019
    Saginaw, Michigan
    Just have it pumped out every few years and don't worry about it. Around here it's $125 to have the tank pumped out. I do it every 2-3 years and consider it to be cheap insurance.
  12. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Sounds cheap. $500 would be expensive. Some charge extra to dig up the lid, and others don't.
    The time between pumping is dependent on the system, the number of people it serves, and their habits. When you get it pumped after 2-3 years the first time, an experienced operator can estimate if you can go longer next time.
    I don't think you need an additive. Enough bacteria will remain after pumping to get things processing again without an additive. You want to not put stuff down the garbage disposer, but instead put into the garbage. A bidet seat or bidet attachment will reduce toilet paper use, and leave you cleaner.
  13. LLigetfa
    Feb 6, 2011
    Semi-Retired
    NW Ontario, Canada
    Some require that you locate and open the lid.
    In Ontario they tried to enact a law requiring tanks be pumped every five years but they succumbed to much protest.
  14. taylorjm
    Dec 18, 2019
    Saginaw, Michigan
    Excellent advice. We actually had a riser and surface mounted lid installed on our tank a couple years ago so they don't have to dig every again. That cost $100, and they actually reduced our pump out cost from $175 each time to $125 because we have the riser and lid.
    I do have one question for you though, see if you ever heard anything like this before. A friend of mine manages a sewage lagoon for a local high school. Basically all the waste gets pumped into a giant pond and he was certified by the state to manage it by checking bacterial levels, etc. So it's like a big open septic tank. He routinely goes out and will pour 50lb bags of cheap dog food into the pond if the bacteria levels get low and that gets them up and going and multiplying again. He said that the idea of not using a garbage disposal with a septic system is an old wives tale and they actually recommend using a garbage disposal because it adds organic food to the tank and keeps the bacterial strong and healthy and keeps them multiplying.
  15. Reach4
    Sep 25, 2013
    Interesting!
    These are from *.edu sites. That doesn't mean they are necessarily right, but the probably don't have a bias on this topic. They either suggest to avoid some things, particularly fats, they also seem to think that the whole volume of solids will contribute to stuff that will need to be pumped. Some is broken down and some contributes to faster sludge.
    https://ossf.tamu.edu/frequently-asked-questions/#Question 4
    https://www.extension.purdue.edu/extmedia/HENV/HENV-106-W.pdf
    https://wsg.washington.edu/wordpress/wp-content/uploads/outreach/Septic-sense.pdf
    https://polk.extension.wisc.edu/files/2010/12/Care-and-Maintenance-of-Residential-Septic-Systems.pdf
    Maybe further research is good. The could be more useful than many topics that are called research.
    https://s3.wp.wsu.edu/uploads/sites/2079/2014/02/septic-additives.pdf has a list of septic additives deemed safe. It says
    However, approval and listing does not guarantee or certify the product is effective. Common household products, such as detergents, bleach, drain cleaners, and toilet cleaners, are excluded from this regulation.​
  16. taylorjm
    Dec 18, 2019
    Saginaw, Michigan
    Thanks, I should have been more clear. I agree that things like fats or grease that can't be broken down easily or will float on the top and risk getting into the leech field, or too much so it ends up increasing sludge. I also found a whole slew of information that said things on both sides. Personally, we only put food waste down, but also have it pumped out every few years, but I wondered how you felt after seeing some of your comments. I'll check out the links you posted in more detail later. Thanks!
  17. Reach4
    Sep 25, 2013
    I have one septic tank that I have gotten pumped twice. So very limited experience. Price for pumping seems very reasonable to me compared to me, typical $300 and more for sewer charges.
    I don't have a disposal.
Similar Threads: best bacteria
Pumps and Tanks Well Forum & Blog. Water is life. Well specs best guess question May 29, 2021
Pumps and Tanks Well Forum & Blog. Water is life. Advice for obtaining which best well pump May 15, 2021
Pumps and Tanks Well Forum & Blog. Water is life. Best Washing Machine & Laundry Tub Pump? Apr 8, 2021
Pumps and Tanks Well Forum & Blog. Water is life. Best way to increase GPM from existing deep well Apr 7, 2021
Pumps and Tanks Well Forum & Blog. Water is life. Best way to bleach/cleanse well? Jan 9, 2021
