As I usually say, definitions are important.
There are basically two types of water for the purposes of our discussion. Surface water and ground water
surface water is exactly what the name implies. It is an ocean, lake, river, stream, etc. If surface soaks into the ground, it becomes...... ground water
ground water is found under the land surface. It’s as simple as that. No not really. If you pump it out of the ground and the excess runs off and ponds, it becomes.....surface water.
Ground water is ground water regardless of its depth. Doesn’t matter if it’s 6 inches, 6 feet or 600 feet it’s all groundwater.
there are different rights that a property owner has depending on whether it is surface water or ground water. These rights vary state by state. What is true in one state may not be true in another state.
western water law is very different than eastern states. Some states you have the right to extract as much water as you want inside your property boundaries. In other states the water belongs to the state and you must obtain a water right to extract the water.
for example, I live in Washington, a western water law state. Any use of surface water, no matter how small requires obtaining a water right from the state. This is also true for ground water, except for certain exempt uses. Which are defined as stock watering, single family domestic use, irrigation of 1/2 acre or less, and commercial or industrial uses not to exceed 5,000 gallons per day. You do not have the right to harvest rainwater because it is....surface water. Unless it infiltrates into the ground and then it becomes.....ground water.
now due to litigation we also have ground water, under the influence of surface water, but that’s probably beyond the scope of this discussion.
clear as water?
