lowyieldwell
Hello, first and foremost, thank you all for your helpful posts, very much appreciated!
Was hoping to get some input from the experts here in terms of an intermediate well water storage system. Such as, what type of system would be best? how much of a budget for this type of project? to build a DIY system or purchase a pre-made system?
Here are the details of the low yield well problems:
- Residential well drilled about 520 feet deep
- 1hp Goulds 5 gpm well pump set at 500 feet deep
- Well-X-Trol WX-205 pressure tank set at 40/60 PSI
- Pentek well pump protector installed
- Well static water level estimated at 470 - 485 feet deep
- Well yield estimated at 0.1 - 0.15 gpm
- Available installation area for an intermediate water tank - inside a garage (30 inch deep X 90 inch wide by 72" high)
- Well water is very hard with lots of minerals
- 4 bedroom, 3 bathroom house (4 people)
- water saving devices installed on showers. The toilets have water-filled bags in the tank to lesson the water usage per flush
- top loading washer machine (1 load per day)
Considered hydrofracking the well but there is no guarantee this will work. Thinking an intermediate well water storage system is a safer bet that should certainly fix the running out of water problems in the house.
Looking for suggestions on what type of system to get? would buying the components separately and building a system be the lowest cost option? best performing option? Is it very difficult to put together as a DIY project?
Also considering buying a pre-built system, something such as this: http://www.wellmanager.com/wellmanager.htm
Costly, but appears to offer more of a management system which should not run the well dry over and over again (thus protecting the well from damage).
Currently the well keeps running dry which is most likely hurting the geology of the well (assumption being: fractures are exposed to oxygen when well water is drawn all the way down, thus the oxidation of hard water minerals could be plugging up the fractures, slowly lessening the yield of the well over time).
Thank you all for your help and suggestions.
