Qwertyjjj
- Messages
- 260
- Reaction score
- 2
- Points
- 18
I have a shallow well about 25ft deep and I'd like to water the nearby garden with a pump.
The pump would have to pump up around 10ft and then across 120ft of polypipe.
From a calculator that resistance means about an additional 15ft of loss so 25 ft head total.
It would be attached to a hosepipe, which is around 300GPH.
Problem is the pump has a much higher GPH at 0 feet, maybe 2000GPH.
Any smaller pumps will not pump up the height.
So, what happens if the flow rate is higher than the output?
Does the pump increase the pressure and burst connections as the extra water will have nowhere to go?
