What else should be replaced when replacing submersible pump?
Atomic1
Maryland
Like the subject says, what other things should be replaced when replacing a submersible? I believe I have a poly drop pipe with a pitless adapter.
Does the drop pipe get replaced?
Oring on pitless?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
If the pipe and pitless look good, the o-ring in the pitless is probably the only thing needed to be replaced. But of course if it will fit I always add a flow inducer shroud to make the motor run cooler and last longer.
