What do the pros consider the "correct" PRV pressure setting?
Jadziedzic
Active Member
New Hampshire
I live on a street with city water supplied at around 120 PSI. Our PRV was just replaced, and the plumber adjusted the new PRV for 70 PSI. I think I've seen recommendations here for around 60 PSI, but I can't find that right now via search. (The new PRV is a lead-free Watts 25AUB.)
I have to admit it feels good to have decent water pressure through all the (EPA-mandated) low-flow fixtures, just want to be sure we're not going to extremes. Thanks!
Watts 25AUB has a filter screen, so if flow drops off, you might want to check the screen.
As long as there is no water hammer or issues im ok at 70 prefer a little lower . I got mine set lower cant remember ill guess 55 but most of my hosebibs are unregulated so those work real good
