What AMP and Wire size Breaker for a 2000Watt /120volt ELECTRIC WATER heater
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Roccero, Mar 26, 2020.
  1. Roccero
    Roccero New Member
    Mar 26, 2020
    Arizona
    The water heater has only one element just need to know the info for breaker and wire size would truly appreciate it ..
  2. Bannerman
    Bannerman Well-Known Member
    Mar 19, 2014
    Ontario, Canada
    A 120-volt water heater usually is equipped with a 1125 watt element.
    If your heater has a 2000 watt element, the amp draw can be easily calculated.
    2000 / 120 = 16.667 amps.
    It appears at minimum, a 20 amp circuit will be required. The usual wire size for up to 20 amps is 12 AWG copper wire.
    Since code often requires the wiring to be sized for 125% of the continuous load, this would then require #10 wire and a 25 amp breaker.
Similar Threads: Wire size
Plumbing Forum, Professional & DIY Advice Can a 10-3 gauge wire be in black jacket? Mar 7, 2020
Plumbing Forum, Professional & DIY Advice Zone wiring--3 zones 2 thermostats wire so 1 zone runs if either of the 2 come on Dec 12, 2019
Plumbing Forum, Professional & DIY Advice Electrical Wire proximity Nov 26, 2019
Plumbing Forum, Professional & DIY Advice Grommets for pump wire in cistern, or......? Aug 24, 2019
Plumbing Forum, Professional & DIY Advice Submersible pump wires identification Apr 9, 2019
