Dorrough
Just an update in case anyone else runs into the same issue. We have a 400 ft + well and it's drilled into karst topology - that means caves. There are lots of caves where we live, and lots of underground hydrology (water) running in underground channels.
After a serious slog of research, I believe that it is just not possible to disinfect a well such as this. Here's why:
1. The water underground can be running at such a high flow rate that any bleach or disinfectant you pour in will be carried away before it can be recirculated. Think of pouring bleach into a river, and then trying to dip clean water out.
2. People used to think that by the time water percolated through all the layers of soil, porous rock and sand all the bacteria would be filtered out. If it was an unbroken layer of material, that would be true. But in karst geology, there are fractures, there are sinkholes that can plunge hundreds of feet. Any one of these channels can carry dirty water into a well.
3. Even if a cave well tests clean, you can't trust that result. It just means for that moment in time your water was clean. Karst is full of channels that might be dry for months at a time or even years at a time, and then come a heavy rain or local flood and water runs through the channel again. Washing accumulated dirt, bat guano, dead crickets, you name it into the water supply. Unsuspecting you drinks it. surprise! Hope you bought one of those Toto toilets that Terry is so sweet on (I did, by the way. See, I have learned something from lurking around here!)
So the bottom line seems to be that if you have a well that connects to a cave system, you have to get some kind of disinfecting system no matter what. I guess that means UV for me. Anybody got any particular brands to recommend or avoid?
